Need help with Skunk 2 manifold installation....
Ok, I have removed the GSR manifold and the black canister thing under it. There is a round vacuum thingy on the right side of the stock manifold, do I have to move that over to the Skunk2 manifold?
Do I really need the ITR TB cable bracket, or can I reuse the one from the GSR TB. I will be using a bored out B16 TB. Can I use the B16 TB sensors without any problems?
Guest
Posts: n/a
If you're using anything else, yes, you need the ITR throttle cable bracket, and LS or ITR throttle cable.
memphiss13
Feb 5, 2003 08:51 PM
