need help replacing crank seal/oil pump
Old Jan 14, 2006 | 07:47 PM
92civeg's Avatar
Default need help replacing crank seal/oil pump
so i just bought a 97 civic ex from so old woman who brought it into the shop that i work in. The car came in because of an excessive oil leak. It appears to becoming from the crank seal/oil pump area but the crank pulley is slinging it everywhere .
My question is can the crank seal be replaced without pulling the oil pump?
and can the oil pump be replace without puling the crank?
the car has 118k and is about a 8 out of 10 all around...i paid 300 bucks for it
Old Jan 14, 2006 | 07:50 PM
rainforest's Avatar
Default Re: need help replacing crank seal/oil pump (92civeg)
yes. you can.
Old Jan 15, 2006 | 08:08 AM
92civeg's Avatar
Default Re: need help replacing crank seal/oil pump (rainforest)
this may sound stupid but is it possible to replace the oil pump without pulling the motor? looking at some pics it looks like there will not be enough clearance between the framerail and the crank to slide it out?
Old Jan 15, 2006 | 10:33 AM
RedlinedVTEC's Avatar
You work in a shop and can't change a front main seal?
Old Jan 15, 2006 | 12:25 PM
92civeg's Avatar
Default Re: need help replacing crank seal/oil pump (RedlinedVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedlinedVTEC &raquo;</TD></TR><TR><TD CLASS="quote">You work in a shop and can't change a front main seal?</TD></TR></TABLE>
well im sure gonna try
Old Jan 15, 2006 | 01:45 PM
SteveoBA8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civeg &raquo;</TD></TR><TR><TD CLASS="quote">this may sound stupid but is it possible to replace the oil pump without pulling the motor? looking at some pics it looks like there will not be enough clearance between the framerail and the crank to slide it out?
]</TD></TR></TABLE>
Drop the engine side mount to see if you will have enough room.
Old Feb 26, 2006 | 09:47 PM
CRXB16B's Avatar
Default Re: need help replacing crank seal/oil pump (SteveoBA8)
i changed my oil pump without taking the motor out it was my first time and ill say it was easy
benin360
Nov 22, 2011 03:12 AM
91(si)hatchey
Nov 6, 2009 12:32 AM
92civeg
Jan 15, 2006 09:12 AM
NWHybrid
Jan 23, 2004 10:19 PM
warwagon
Sep 25, 2003 09:31 PM
