Need help with new wheels
Old Aug 1, 2002 | 05:58 AM
Nate B's Avatar
Default Need help with new wheels
Can anyone tell me if my stock lugnuts/valvestems will work with Rota Slipstreams? It's for a 2001 Type R. I'm having the tires put on the wheels today, and I'd hate to find out that my lugnuts and valvestems won't work. I plan on upgrading the lugnuts ASAP but did not get a chance to yet and have an appointment in 3 hours to have the wheels swapped out. Hope someone can help me out...Thanks guys.
Old Aug 1, 2002 | 06:53 AM
Canuk_SiR's Avatar
Default Re: Need help with new wheels (KILLERB18)
both should work just fine
Old Aug 1, 2002 | 07:31 AM
Nate B's Avatar
Default Re: Need help with new wheels (Canuk_SiR)
Do you know this from experience or are you taking a guess?
Old Aug 1, 2002 | 09:16 AM
dphi's Avatar
I know people who have ran stock lug nuts on rotas for quite a while with no problems.
Old Aug 1, 2002 | 09:23 AM
DSF's Avatar
DSF
Read this thread...
http://honda.hybrids.jp/forum/showfl...w=&sb=&o=&vc=1
Old Aug 1, 2002 | 09:24 AM
poison's Avatar
i'd suggest very good locking ones if u don't already have 'em
Old Aug 1, 2002 | 10:56 AM
BROOD's Avatar
After many times bolting up wheels on Hondas and other cars, including aftermarket and oem wheels................................
I would NOT suggest using the oem Honda lug nuts with aftermarket wheels.
~OEM Honda uses round seat lug nuts
~aftermarket used tapered seat lut nuts
Plus, I would NOT suggest usinf tapered lug nuts with oem Honda wheels.
Using oem Honda lug nuts on your Rotas would probably hold a torque but the are simply not correct....why chance it. IConsidering you spent a decent load of cash on the wheels and tires, why would you not do it the right way?And about the valvestems......take a closer look at them. Rubber stems cannot be reused, metal stems can be reused with new gromets. OEM Honda stems are going to be rubber.....don't worry I doubt $1.00 per valve will hurt your wallet much.
[Modified by SLPR, 12:01 PM 8/1/2002]
D3vin
Feb 21, 2011 06:36 PM
Ming Tsai
Dec 4, 2007 07:19 PM
seprinakk
Nov 15, 2005 10:57 AM
