need help with my vtec problem on jdm b16
Old Aug 11, 2010 | 07:36 PM
civicdozer's Avatar
Default need help with my vtec problem on jdm b16
i did a jdm b16 swap in my 99 civic after i got the motor in i drove it and the speedometer wasnt workin i narrowed it down to the signal wire on the vss sensor so i ran a new wire from the sensor to the back of the cluster and now my speedo works but still no vtec could someone help me and let me know what i can do to fix this
Old Aug 11, 2010 | 08:02 PM
CRX Si69's Avatar
Default Re: need help with my vtec problem on jdm b16
did you wire the vtec up right? hows the solenoid?
Old Aug 12, 2010 | 08:24 AM
civicdozer's Avatar
the car is a 99 ex so it had vtec already but when i did the swap i converted it to obd1 with the harness and the jumper harness when i first started it the tach didnt work either but on the drivers side by the shock mount theres a blue wire for the tach so i ran it there.will i have to rewire the vtec cause the car it came out of everything worked in that car.
Vryantec
Aug 10, 2018 08:30 AM
Amatocrx
Nov 21, 2013 07:18 AM
jvillagran2000
17
Feb 2, 2009 06:06 AM
sammydigital
Jun 9, 2006 05:31 PM
