need help on my bad fuel consumptions
Old Feb 15, 2005 | 08:50 PM
gamakichi77's Avatar
Default need help on my bad fuel consumptions
i'm using B16A stock engine on my civic EK3, manual Tranny with P30 ecu and wirings.
rite now, i did install ctr cams with stock valve trains kit. i did advanced my exhausts cam about 2 degree.
rite now, when i turn off my air-conds, my fuel at air/fule ratio is good stoich with a little bits rich...that is good for NA engine as i know...and it runs good also..
but when i turn on my air-conds, my fuel drop to lean.........and my fuel consumptions are too bad when i always turn my air-conds....
pls help me..thanks.
Old Feb 15, 2005 | 10:41 PM
Lord Helmet's Avatar
Default Re: need help on my bad fuel consumptions (acidburns_di)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acidburns_di &raquo;</TD></TR><TR><TD CLASS="quote">i'm using B16A stock engine on my civic EK3, manual Tranny with P30 ecu and wirings.
pls help me..thanks.</TD></TR></TABLE>
there's your problem. also having ctr cams doesn't help your cause either. BTW what did you expect when you started to modify your engine? 35+ miles to a gallon?
Old Feb 16, 2005 | 03:57 PM
Default Re: need help on my bad fuel consumptions (sleeperciv)
previously for about 6 month, its running good....fuel consumptions is not too bad, can go for 400km for full tanks......rite only 220km per full tanks....very bad consumptions.....
filipedua
Feb 28, 2007 06:01 AM
Rowdy
38
Jun 10, 2003 03:57 PM
ZERO COOL
Feb 10, 2002 02:01 PM
SilverVTi
Sep 1, 2001 09:53 AM
