need help installing clutch
Old Jul 9, 2007 | 06:08 PM
hmongthug911's Avatar
Default need help installing clutch
need picture detail and step by step instructions for installing a clutch for a 97 honda civic ex just bought a stage 3 xtd racing clutch.
Old Jul 9, 2007 | 07:04 PM
EG civic's Avatar
Default Re: need help installing clutch (hmongthug911)
Here u go.
http://www.c-speedracing.com/h...h.php
Old Jul 10, 2007 | 04:55 PM
Default Re: need help installing clutch (EG civic)
thanks for the site but its for a b18 not the d16 i think there is a difference in changing the clutch.? or is it about the same>?
Old Jul 10, 2007 | 06:28 PM
builthatch's Avatar
MiG-21 superfan
look around in here-
http://www.redpepperracing.com...M/144/
no better info than that from helms ; )
Old Jul 10, 2007 | 07:31 PM
hitekper4mance's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmongthug911 &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the site but its for a b18 not the d16 i think there is a difference in changing the clutch.? or is it about the same&gt;?</TD></TR></TABLE>
I have no clue. But, I think if you are going to be changing your own clutch, the procedure would all be pretty much the same. Only thing to worry about would be the torque specs. May have a slight difference in bolts or something but, if you can drop the tranny yourself, the clutch probably wont be that bad.
Old Jul 11, 2007 | 11:02 AM
DecentCivicZ6's Avatar
B A N N E D
yeah its EASY changing a D series clutch, i changed mine 3 times in 1 week, ( long story)
its exactly the same as B series, except when you get to the throw out bearing, The D series is earier to remove. Just take all the mounts loose except driver side.remove hydraulic lines, starter, all the 17mm bolts on tranny to block,and the one 19mm near rear mount..might be 2. pop axles loose, i mean, ITS EAAASSSSYYYY...just look at it...its easy...And once the tranny is removed, just need 10mm, and 12mm to remove clutch and flywheel, How many miles are on the engine?? if alot id replace the REAR MAIN seal while you Are in there...thats also very easy to replace.
Old Jul 11, 2007 | 03:26 PM
Ron454321's Avatar
Make sure you have 12 point sockets, can't tell you how many people come to me to borrow them when changing thier clutch
Old Jul 11, 2007 | 04:47 PM
B A N N E D
yup ^
1BADEGDC2
17
Jul 11, 2008 11:57 AM
tenny91
Sep 1, 2007 03:25 AM
DC494LS
Oct 8, 2005 01:58 AM
getdrugtoday
Dec 17, 2004 04:56 PM
