Need Help Failed Emissions Test!
Old Aug 7, 2003 | 02:38 PM
Bizarre's Avatar
Default Need Help Failed Emissions Test!
Yesterday my car went for an emissions test end it failed. The car is a 94 Civic Si. The thing that I failed on was my "HC ppm" reading. The limit was 200 and my car did 216. This was only for the idle test, my car wasn't put on the rollers because it was to low. I also past everything else with flying colors. Does anyone know what this could be? I pulled the plugs they look fine, checked all vacuum hoses they were all connect, exhaust doesn't smell of anything and I was running 92 octane. My only mods are a CAI and a magnaflow muffler welded onto the stock piping. I am going to change the cap, rotor, plugs, wires, and fuel filter(I know this probably won't help but I have to change them anyways). Hopefully someone knows what this could be. TIA!
Old Aug 7, 2003 | 02:41 PM
nonsense's Avatar
Default Re: Need Help Failed Emissions Test! (Bizarre)
did you warm up the CAT enough before the test? It could be a cold cat converter or a bad cat converter.
Steve
Old Aug 7, 2003 | 02:47 PM
Bizarre's Avatar
Default Re: Need Help Failed Emissions Test! (nonsense)
Thats what I was thinking but how long does it take for it to warm up? I drove it for about 15 minutes before I brought for the test.
Old Aug 7, 2003 | 05:11 PM
Bizarre's Avatar
Bump
Old Aug 7, 2003 | 07:36 PM
HONDADNA's Avatar
the cooling fans needs to come on twice (normal operating )
Old Aug 8, 2003 | 05:58 AM
EE_Chris's Avatar
Why are you running 92 octane? Unless you NEED it, throw some 87 back in there and retest. HC are unburned fuel...and if your not taking advantage of the 92, that could be your source for a few more HydroCarbons.
Old Aug 8, 2003 | 07:39 AM
Crazydave's Avatar
Default Re: Need Help Failed Emissions Test! (EE_Chris)
http://slowspeed.com/articles/...s.pdf
Old Aug 8, 2003 | 07:40 AM
Crazydave's Avatar
technially they should have required you to fix your car so that it could fit on the dyno
they were being cool to you
Old Aug 8, 2003 | 09:40 AM
Crazydave's Avatar
Default Re: Need Help Failed Emissions Test! (Crazydave)
here is a usefull chart
http://www.firstfives.org/faq/smog/smog_faq.html
Old Aug 8, 2003 | 09:51 AM
HumanResource's Avatar
Default For HC reduction
SCC did a MOTO-VAC engine cleaning service on their project Miata. Dropped HC WAY DOWN! If you can't afford this, u might wanna try the ATF cleaning method, but give yourself about a week of some "throat-clearing" hard driving to make sure it's all out.
Old Aug 8, 2003 | 10:29 AM
Bizarre's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">Why are you running 92 octane? Unless you NEED it, throw some 87 back in there and retest. HC are unburned fuel...and if your not taking advantage of the 92, that could be your source for a few more HydroCarbons.</TD></TR></TABLE>
I was running 92 because I thought it burnt cleaner. Also when I did my cap and rotor last night I noticed that my timing is advanced all the way . After reading some of the links I think that this might be causing me to fail, so Im going to try to put it to the stock timing. Thanks for the help guys
Old Aug 8, 2003 | 10:31 AM
Crazydave's Avatar
Yeah..
put it back to stock timing!
Old Aug 9, 2003 | 06:46 AM
JUNDC2's Avatar
man I failed the emission test too.
zzzzzzzz
12
Aug 2, 2008 11:46 AM
civic_91
Feb 10, 2003 12:41 PM
AK94GSR
Aug 8, 2002 08:28 PM
cvcc721
11
Jul 3, 2002 03:02 PM
