Need help with electrical issue.
Old Nov 2, 2016 | 02:19 PM
Jakeumm's Avatar
Default Need help with electrical issue.
So my Honda kept blowing 80a main battery fuses and not getting any power, ended up disconnecting the alternator and it I was able to finally get power. I have tested the alternator at autozone and they said it's reading okay. And even with the alternator disconnected the car still won't start. I tried starting the car and as soon as I do all power stops and I hear a popping/springing noise. So I'm thinking it might be a bigger issue than just the alternator. Anyone have any idea what could be done?
Old Nov 2, 2016 | 03:48 PM
fcm's Avatar
fcm
Old Fart
Default Re: Need help with electrical issue.
Have you checked/redone your main grounds, [batt. to chassis and chassis to engine]?
MM&Y year of car along with trim level and any mods would help. 94
Old Nov 3, 2016 | 05:11 AM
Jakeumm's Avatar
So it's a 2005 Civic LX, I realized that the reason it wouldn't start with the alternator disconnected was probably cause the battery was dead (duh I should have thought of that). But last night I bought some 8g wire and ran it from the alternator to the fuse box and it didn't seem to pop so I'm thinking that the alternator power wire was shorted. I didnt crimp the head on and bolt it in as it was getting dark but when just touching ends I didn't get any fuses blown. I'm installing that wire today and will update
Old Nov 4, 2016 | 04:34 PM
Jakeumm's Avatar
Solved! After putting in a new alt power wire it was still doing the same thing. So I went and bought a new alternator and saw that there was supposed to be a piece of plastic between the alternator and the power cord that was causing it to short out. I had to do was put in a new piece of plastic. Is just an FYI if anyone comes across the same issue
Old Nov 5, 2016 | 11:00 AM
holmesnmanny's Avatar
Could you take a picture? I'm kinda curious what the issue was.
eggie75
Mar 25, 2010 04:37 PM
bryantbb6
Feb 19, 2010 02:41 PM
Choy
20
Jul 20, 2009 07:11 AM
blaze_125
Sep 24, 2007 09:46 AM
4gen
Audio / Security / Video
May 28, 2004 03:33 PM
