Need help diagnosing a noise....
Old Feb 11, 2002 | 10:39 AM
PornStarRacingB16T's Avatar
Default Need help diagnosing a noise....
Ok so I am getting a "thumping" sound from my left front wheel. At first I thought CV joint, but it seems to happen when going straight as well as turning AND it only happens when I am coasting. If my foot is on the gas or brake it doesnt do it.
Any ideas what I should take a look at?
TIA
Jeff
Old Feb 11, 2002 | 10:55 AM
Spade's Avatar
Default Re: Need help diagnosing a noise.... (PornStarRacingB16-T)
fast or slow thump?
Old Feb 11, 2002 | 11:02 AM
976's Avatar
976
New User
Default Re: Need help diagnosing a noise.... (Spade)
CV joing - drive axle
Alignment; toe, control arms, strut/shock, etc. - Not too likey.
Bent wheel
Tire pressure?
Check these, if not then I would suggest it is your drive axle - boot.
Old Feb 11, 2002 | 11:05 AM
Speed of the thump is proportional to the speed the car is going, fast = fast thump, slow = slow thump
Old Feb 11, 2002 | 11:15 AM
Crazydave's Avatar
Flat spot on your tire..
have you ever locked up your brakes?
Old Feb 11, 2002 | 11:26 AM
Default Re: Need help diagnosing a noise.... (Crazydave)
Yes I have, a couple of my friend suggested this, but surely it would still make the noise when breaking and accellerating tho wouldnt it? I guess the only way to fix it would be a new tire :-/
Old Feb 11, 2002 | 11:28 AM
Duck Sauce's Avatar
You need a new tire.
Old Feb 11, 2002 | 12:57 PM
bob01721's Avatar
Why don't you switch that wheel with another one and see if the problem moves? That'll help you isolate it.
Old Feb 11, 2002 | 05:33 PM
dirtySOHC's's Avatar
Default Re: Need help diagnosing a noise.... (bob01721)
might sound stupid but i had big *** nail stuck in my front tire and it was making a loud thump. checked the tire out and sure enough there it was.....
etb75
Honda Civic (2001 - 2005)
Nov 27, 2011 12:56 PM
VTECROAR96typeR
Suspension & Brakes
Feb 20, 2009 09:49 AM
garyc17
Jan 10, 2007 10:15 AM
NyTrYdEr AcCoRd
Nov 23, 2003 08:55 PM
Quetzolcotl
Sep 20, 2002 06:21 PM
