NEED HELP WITH CA SMOG!!!!!
Old Jul 26, 2023 | 11:48 PM
DonReyn's Avatar
5 Year Member
Icon4 NEED HELP WITH CA SMOG!!!!!
Here is my smog paperwork on my 1993 Honda civic EX please if anyone can chime in that would be great.
I'd like to say as well I slightly bumped the compression up in this engine to 10:1 ish which shouldn't really hurt anything... So i thought..
I'm going to mess with ignition timing and replace the cat.. The cars ignition timing is off I know dumb move.. I switched ECU's and my tuner had the ignition timing set & I didn't mess with it before smog.
Any helpful tips in helping me would be awesome. thanks
Old Jul 26, 2023 | 11:59 PM
DonReyn's Avatar
5 Year Member
Default Re: NEED HELP WITH CA SMOG!!!!!
I also installed a new Denso O2 sensor before smog but hopefully with the O2, my new cat (I just ordered it tonight) and adjusting my ignition timing I should pass.
Old Jul 27, 2023 | 07:38 AM
Chance EG's Avatar
These threads sure to seem to be popping up more frequently lately.
Old Jul 27, 2023 | 08:22 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Hot smogs are expensive now
OP, set your idle, set your ignition timing, put some fresh gas in it, go out for a long drive, take the car to get smogged.
Old Jul 27, 2023 | 06:22 PM
DonReyn's Avatar
5 Year Member
Post Re: NEED HELP WITH CA SMOG!!!!!
Thank you for your feedback! I will post my results if I fail or pass in 2 weeks from today!
I see you also live in the central valley, That's cool, I'm in Modesto!
Old Jul 27, 2023 | 11:30 PM
DonReyn's Avatar
5 Year Member
Yes it sucks. :^/
Old Jul 30, 2023 | 12:26 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
The CO2 is fantastic .Probably credit the high comp pistons.
Based on the rest of the numbers, Id say the cat is bad...
Old Jul 31, 2023 | 03:35 PM
DonReyn's Avatar
5 Year Member
Hello thanks for chiming in! I have a new CARB compliant catalytic on the way from rock auto should be here on Wednesday. I will post the results pass or fail and go over what I did if I passed or what I will do next if I have to retake the test.
Old Aug 1, 2023 | 11:41 AM
ShinsenTuner's Avatar
No Jodas
You need to take the car on a really long drive to heat up that cat before testing.
Old Aug 28, 2023 | 07:31 AM
DonReyn's Avatar
5 Year Member
Hello, I have a BIG UPDATE!!!
I PASSED my smog!! Here is what I did hopefully I can help many people in the future with this thread!
I adjusted the idle air adjustment screw on my throttle body once the car was completely warmed up, then I set the ignition timing and I continued the dial in the idle air screw and timing to get everything as perfect as I could.
That was a big help! Also I did put a new catalytic converter on my car and everything was good to go!!
A BIG THANK YOU TO EVERYONE WHO COMMENTED ON MY POST TRYING TO HELP ME OUT!
Old Aug 28, 2023 | 08:43 AM
Chance EG's Avatar
The sea turtles of America thank you!
Dazer 1991
Aug 15, 2012 07:09 AM
HardSaltydogg
Mar 7, 2012 10:25 AM
oneforce
Mar 7, 2006 07:37 AM
haophat
Jan 21, 2004 08:30 PM
ITR#00-1077
May 21, 2002 01:03 PM
