need help with b16 knock sensor
Old Feb 7, 2008 | 06:38 AM
00sirkidd's Avatar
Default need help with b16 knock sensor
my 00 honda civic si is throwng code number 23 which is the knock sensor.. i found the knock sensor and there is one there but nothing pluging into it.. what should i look for? also is it ok to drive like this it seems to drive normal... thanks
Old Feb 7, 2008 | 08:14 AM
00sirkidd's Avatar
Default Re: need help with b16 knock sensor (00sirkidd)
anyone?
Old Feb 8, 2008 | 02:08 AM
ghostskinner's Avatar
find the wire that plugs in to it and plug it in the wire should be under the intake manifold
Old Feb 8, 2008 | 11:20 AM
00sirkidd's Avatar
Default Re: need help with b16 knock sensor (ghostskinner)
do u no where the knock sensor plugs into the ecu? i am just goin to run my own wire
Old Feb 9, 2008 | 01:50 PM
Turbo B18C EJ6's Avatar
Im trying to understand what you are saying here. First off is your car stock and is it a 00 si? it should already have the sensor plugged in to it already. if so like just said above you should look for a connector hanging loose behind the engine.
blasterman87
Jun 6, 2010 07:04 AM
00sirkidd
Feb 8, 2008 11:22 AM
quicky_hatch12
Oct 7, 2005 11:59 AM
EF_LSVtec
Apr 10, 2003 11:25 AM
