NEED HELP ASAP PLEASE GSR BUILD
Old Jan 14, 2010 | 06:22 PM
Dlamazing's Avatar
Default NEED HELP ASAP PLEASE GSR BUILD
ok heres the problem ht i got a gsr swap that im building for boost i got cp pistons manley turbo tuff rods arp head studs and all oem gaskets and new water pump oil pump the whole 9 now i took apart my motor compleatly and i found that my crank journals are scored! the bearings are toast!!! did not spin a bearing the motor was running b4 i took it apart so i did not want to machine my crank so i got a good crank off another b18c1 now my ? is how do i determain the main bearing color/size the new crank i got has not been machine its with oem specs so do i go with the code of the block and the numbers and letters off the crank to determin bearing or is there another way of figuring this out please i apreciate the help im trying to build my motor asap
Old Jan 15, 2010 | 04:28 AM
Dlamazing's Avatar
Default Re: NEED HELP ASAP PLEASE GSR BUILD
ttt
Old Jan 17, 2010 | 06:52 PM
Dlamazing's Avatar
ttt help please
Old Jan 17, 2010 | 07:00 PM
zedron's Avatar
I just do a plasti gauge to find out the clearances and just order the bearings accordingly?
Old Jan 17, 2010 | 07:05 PM
Dlamazing's Avatar
i know i have to plasti gauge but i have a new crank and dont have old bearing to messure with only the old bearing from the old crack that are burnt with cranks in them i dont think its a good idea to put those bearing in my new crank to mess up my journals plus there acl standards FMl
Old Jan 17, 2010 | 07:08 PM
non-VTEC's Avatar
take the numbers/letters off the crank and block and select the correct size bearings as a starting point for measurements.
if you have a helms manual you should be able to find this info easily.....if you are trying to assemble it without that manual then good luck to you.
Old Jan 17, 2010 | 07:13 PM
Dlamazing's Avatar
yah i got the book but i thougth that once you change your crank your block codes and crank codes no good ?
Old Jan 18, 2010 | 05:30 AM
non-VTEC's Avatar
no the codes will still work. they will give you a good starting point. you should still measure though.
Old Jan 18, 2010 | 08:25 PM
fusion645's Avatar
make sure you follow the torque specs and patterns of tightening. That might of been the problem of the crank journals and bearings got scored. Im on a B18C build myself.
91(si)hatchey
15
Apr 28, 2009 07:35 AM
2000dc2
Mar 17, 2009 07:31 PM
H9Omega
Mar 18, 2007 08:51 AM
4drsedaneg
Dec 27, 2004 08:31 PM
