NEED HELP ASAP!!!
Old Mar 25, 2008 | 01:44 AM
92J-SpecHatch's Avatar
Default NEED HELP ASAP!!!
just got the car done for the big tune tomorrow.. and now NO SPARK... changed distributors.. still nothing.. changed ecus.... still nothing.. someone help ASAP..
Old Mar 25, 2008 | 08:50 AM
N8's Avatar
N8
Default Re: NEED HELP ASAP!!! (92J-SpecHatch)
What swap and what ecu are you running?
Old Mar 25, 2008 | 05:48 PM
Default Re: NEED HELP ASAP!!! (N8)
chipped comp. with 1600 injectors ...ls vtec
Old Mar 25, 2008 | 06:22 PM
91DA9's Avatar
That is a tough one, as you have already singled out the number one cause of no spark. (dizzy)
Have you checked the plugs? How do you know there is no spark, a timing light, or physically checking the plugs?
Old Mar 25, 2008 | 06:27 PM
Default Re: NEED HELP ASAP!!! (91DA9)
i checked with a screw driver and spark plug wire and i can hear the fuel pump turn on.....all my grounds are there
Old Mar 25, 2008 | 06:57 PM
91DA9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92J-SpecHatch &raquo;</TD></TR><TR><TD CLASS="quote">i checked with a screw driver and spark plug wire and i can hear the fuel pump turn on.....all my grounds are there</TD></TR></TABLE>
So you are basically saying your secondary voltage works, but the plugs themselves have not been checked. By saying you "just got the car done" do you mean you had never ran it before, or you were just reworking some things before a big day, and it has ran fine before?
I would check the plugs for correct gap and then actually check them for spark outside of the combustion chamber.
Old Mar 26, 2008 | 09:22 AM
its a fresh rebuild.. and everything went back the same way as it came out.. thats why i cant figure it out.. checked all my wiring multiple times... it has power going into the distributor from the harness but for some reason it still wont get no spark..
Modified by 92J-SpecHatch at 1:39 PM 3/26/2008
94hatchy
21
Nov 13, 2010 05:23 PM
crxkid24
Jul 25, 2006 12:02 PM
raczyk
Dec 19, 2005 04:01 PM
EckoTech
Oct 30, 2004 01:25 PM
ViperRedCRX
Jun 29, 2003 07:48 AM
