need help!?!
Old Jul 11, 2003 | 01:52 AM
iwouldHITit's Avatar
Default need help!?!
ok i have a crx with a b18b and i was doing some burn outs ;D and busted the bolts holding the driver side motor mount.. one bolt snapped in half and the other 2 stripped >
-2 top holes i think are stripped cause i found one bolt with shavings and i dont know where the other bolt is.
-bottom hole the bolt snapped in half
??how do i fix this mess. can i just retap the holes??
Old Jul 11, 2003 | 02:08 AM
xteg95's Avatar
Default Re: need help!?! (iwouldHITit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iwouldHITit &raquo;</TD></TR><TR><TD CLASS="quote">ok i have a crx with a b18b and i was doing some burn outs ;D</TD></TR></TABLE>
might be better off buying a new mount, ppl are always selling their old ones here.
Old Jul 11, 2003 | 02:32 AM
J2turbo21's Avatar
Default Re: need help!?! (xteg01)
Try to see if the holes will take the bolts still and your gonna have to get a bolt extracter(sp) and get the bottom one out.How did this happen,where you using the correct bolts for thos mounts?
Old Jul 11, 2003 | 07:28 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: need help!?! (J2turbo21)
Worst case scenario is you have to take it to a machine shop and have them re-weld up the busted holes then drill and tap for brand new threads. I priced this at around $100 at a local machine shop because I found a ZC in a junk yard with busted mounts on the block.
Old Jul 12, 2003 | 03:39 AM
Default Re: need help!?! (DaX)
one of the top holes accepted the bolt but the other didnt..i guess i have to retap it. do i have to take it to the machine shop or can i just retap it myself?
guero2craze
Oct 11, 2008 04:43 AM
MNCRXSi
Mar 9, 2008 01:47 PM
gpilethbridge
Apr 4, 2007 01:41 PM
BJOnewiper
Dec 10, 2005 01:15 PM
DMF
Oct 12, 2003 09:30 PM
