NEED HELP!!!!
i put a skunk2 intake on my b16a2 and now the throttle cable bracket is big enough to fit.....which oem bracket do i need to be using in a dc integra for this to work.....
also i am trying to wire up my gm3bar into my integra with my chasebays harness.....the wires on the harness are yellow w/green stripe....green w/ white stripe....red w/ green stripe......which wires go to A B C on the three bar?
thanx for the help
thanx for the help
B-SERIES
A = gnd Green/White
B = map signal White
C = 5v Yellow/Red
For verification check inside the Honda Map sensor plug. The pins may be labeled with V O G - for Voltage, signal and ground.
A = gnd Green/White
C = 5v Yellow/Red
in my dc integra i have a gsr with b16 head.....what throttle cable and bracket do i need to use for my skunk2 intake mani.....
and please more help on the wiring....
"you can use an ITR tb bracket holder and cable on a skunk2 manifold"
b16clutch
Dec 28, 2005 09:55 AM
