Need advise on getting my H22 Lude started again
Old May 5, 2007 | 05:58 PM
TopEndUSA's Avatar
Default Need advice on getting my H22 Lude started again
Here's a list of things I have tried:
I have replaced the main relay
took out the MSD SCI ignition box and installed the MSD Digital 6
soldered the wires for the injector clips and ecu (the ones cut for the FJO driver)
I reset the timing (will triple check it again tomorrow)
Replaced the spark plugs
replaced the cap on rotor on the dizzy
replaced the dizzy with another one I had
sprayed starter fluid in the intake (it just cranked and cranked and made a puff sound)
Checked all the fuses several times
I am out of ideas, anyone got any advice.
Modified by MardreRacing at 5:27 PM 5/6/2007
Old May 6, 2007 | 06:08 AM
TopEndUSA's Avatar
Default Re: Need advise on getting my H22 Lude started again (MardreRacing)
bump
Old May 6, 2007 | 01:53 PM
speedworks's Avatar
make sure it is in time and the spark plug wires are in the correct order.
Old May 6, 2007 | 03:15 PM
TopEndUSA's Avatar
Default Re: Need advise on getting my H22 Lude started again (speedworks)
I will recheck the timing, but I have set it twice. As for the plugs, they are in the right order.
Old May 7, 2007 | 07:22 AM
Mikey3000's Avatar
does it still crank and its just doesn't fire?
do u hear your fuel pump prime?
have u tried another ecu?
Old May 7, 2007 | 07:52 AM
qksl2's Avatar
Default Re: Need advice on getting my H22 Lude started again (MardreRacing)
Sounds a lot like this eh?
https://honda-tech.com/zerothread/1976414
Ian
Old May 7, 2007 | 05:57 PM
TopEndUSA's Avatar
Default Re: Need advise on getting my H22 Lude started again (Mikey3000)
Yep it cranks and doesn't fire. The pump is priming and no I haven't switched the ECU. It's the AEM EMS and the laptop says it's running fine.
Old May 7, 2007 | 05:59 PM
TopEndUSA's Avatar
Default Re: Need advice on getting my H22 Lude started again (qksl2)
Yep.....seems like the same problem
Old May 8, 2007 | 02:14 AM
TopEndUSA's Avatar
bump
Old May 8, 2007 | 04:39 AM
King V's Avatar
Did you check the signals off the cam/crank sensors? They might be in the distributor(they're both in my distributor<B16A&gt. Could be there.
Old May 8, 2007 | 01:42 PM
TopEndUSA's Avatar
Default Re: Need advice on getting my H22 Lude started again (200kCivicSI)
I thought about that, so I switched distributors. still nothing
Old May 8, 2007 | 03:13 PM
Mikey3000's Avatar
in the title when u say "started again" i suppose u mean it used to run fine. did u do anything to it during its downtime?
Old May 8, 2007 | 07:02 PM
TopEndUSA's Avatar
Default Re: Need advice on getting my H22 Lude started again (Mikey3000)
Yep, I blew a headgasket, so I had to change that. The only other upgrades are the turbo and manifold
Old May 9, 2007 | 04:25 AM
Mikey3000's Avatar
have u checked all the vitals....fuel out the injectors, spark, compression?
Old May 9, 2007 | 02:20 PM
TopEndUSA's Avatar
Yep. will recheck the injectors though
Old May 11, 2007 | 03:35 PM
TopEndUSA's Avatar
Nope the AEM EMS isn't pushing a signal to the injectors. I just did a noid light test and I got nothing from the ems, but when I put a stock ECU in I got a blinking light. Calling AEM now.
srt4pilot
33
Jun 22, 2009 09:36 PM
GUA-D'zCb-7
Jan 10, 2008 05:23 PM
TopEndUSA
May 11, 2007 04:19 PM
TopEndUSA
May 11, 2007 03:35 PM
whitediamond642
Mar 28, 2005 04:45 AM
