Need advise with crv
Old Sep 26, 2016 | 10:35 AM
hondaciviceg559's Avatar
Default Need advise with crv
Hey guys. I have a 1998 honda cr-v. I am stumped on my next step.
The car failed smog(california) today. It registered as a gross polluter. So the catalytic needs to be replaced.
My question is: do all b series use the same catalytic converter? Which would allow me to use a cat from a civic.
second option is: would I need to go with a California catalytic converter or could opt out for a universal one? Would the universal one throw a check engine light and fail the tail pipe test? The main goal is to get the at to pass smog. Thanks.
Old Sep 26, 2016 | 02:26 PM
fcm's Avatar
fcm
Old Fart
Default Re: Need advise with crv
As long as cat is "compliant" where you are your good.
Check part numbers, go to ... Honda Automotive Parts find the P/N for your car an check other Hondas of the same year, [to start with] warning OEM cats are not cheap,
your better off with an OEM "replacement" cat, as long as it is compliant, or are you thinking a used one? 94
soup06
Sep 30, 2009 04:20 AM
teewhy55
Nov 30, 2006 01:10 PM
killaj12
Aug 3, 2005 11:31 AM
hatchinprogress
Nov 6, 2004 05:23 AM
PearlWhiteAccord
Jan 16, 2004 08:31 AM
