My velocity stack
Old Nov 15, 2005 | 05:04 PM
VtecDA9's Avatar
Default My velocity stack
Summitracing.com - RS akimoto velocity stack $20
Orchard Supply Hardware - Metal screen $3.00
I just double screened the velocity stack. Good for the track and cruising the neighborhood.
Old Nov 16, 2005 | 07:16 AM
ekgcool's Avatar
Default Re: My velocity stack (VtecDA9)
Looks good. Get that to a dyno and see if you made more power!
Old Nov 16, 2005 | 07:26 AM
youtouchmytralala's Avatar
stock air box : free
having your engine last: priceless
Old Nov 16, 2005 | 02:05 PM
93civic_sedan's Avatar
dyno results...I see lots of people running those screens on turbo'd cars
Old Nov 16, 2005 | 02:40 PM
-ILLICIT-'s Avatar
Default Re: (93civic_sedan)
basically its for high performance/turbo race cars for sorta ram charging the air, on a stock car there wont be much advantage,on a turb you got the compressor sucking the air at higher speeds so this helps, note on your pic by the battery (near front left i think???) so youll basically be sucking hotter air than stock and probably not improving your performance at all/none/reducing it (well see) this is the IDEAL application for them, where they are in open air on a turbo charged car,
http://www.performancecar.co.n...e.jpg
the best thing you should do, would be to get someone(or yourself if you can weld) is to find the ideal intake length for your engine(i.e tuned intake) THIS should increase power more and then if ya wanna you could always put your velocity stack on that lol, theres plenty of books and sites that will tell you the formulas for doing it,i used a book by this english guy(quite thick with an orange cover, cant remember name of guy book is called advanced engine technology but its VERY good! he also covers everything else to do with engines)
hope that helps
Old Nov 16, 2005 | 05:33 PM
VtecDA9's Avatar
Default Re: (illicit_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by illicit_ &raquo;</TD></TR><TR><TD CLASS="quote">basically its for high performance/turbo race cars for sorta ram charging the air, on a stock car there wont be much advantage,on a turb you got the compressor sucking the air at higher speeds so this helps, note on your pic by the battery (near front left i think???) so youll basically be sucking hotter air than stock and probably not improving your performance at all/none/reducing it (well see) this is the IDEAL application for them, where they are in open air on a turbo charged car,
hope that helps</TD></TR></TABLE>
Thanks for the reply. I got cooler air getting scooped up through that hole. I cut the panel so that the air hits the bend like a skate ramp and shoots upward toward the hole. Kinda rigged but the intake pipe after a long drive is always pretty cool in temperature and even cooler at the filter end. Oh and this was with a filter. THIS VELOCITY STACK IS JUST FOR LIMITED DRIVING.
Old Nov 16, 2005 | 07:08 PM
-ILLICIT-'s Avatar
Default Re: (VtecDA9)
sweet well itll definitely help with the hole ay , couldnt see it in first pic lol
later-
Old Jan 3, 2011 | 12:31 PM
507davo's Avatar
and the questions issssssss.......
the velocity stack improve o not my performance on the track!?
Hiboost 2.0
Sep 18, 2011 06:26 AM
fastfour
Honda S2000
13
Oct 29, 2007 10:40 AM
SIred91
Oct 19, 2006 07:09 PM
Viorent Grip! EG
Feb 7, 2006 08:41 AM
Fink2iCe
Feb 7, 2005 09:24 AM
