is my motor blown?
Old Feb 11, 2004 | 01:44 PM
jdmcivicdx's Avatar
Default is my motor blown?
while i am driving whitish smoke comes out of the exhaust when i shift. The check engine light is flashing non stop. I jumped the maintenance wires together and pulled a code 71, 72 and 74. Engine misfires. What does this mean?
Old Feb 11, 2004 | 01:57 PM
95 LS's Avatar
Default Re: is my motor blown? (jdmcivicdx)
Probably your headgasket. Look at your oil and you can tell. Did your car overheat badly?
Old Feb 11, 2004 | 02:04 PM
jdmcivicdx's Avatar
Default Re: is my motor blown? (95 LS)
no overheating prob yet. car seems to drive with the same power as before. But the smoke coming out the exhaust is alot. Plus the flashing ecu thingy has me concerned. What else could cause these symptons?
Old Feb 11, 2004 | 03:31 PM
mattssi's Avatar
Possibly your car is having ignition troubles?
Old Feb 11, 2004 | 05:23 PM
Jimmy's Avatar
Global Moderator
To answer your question:
Your car wouldnt be running right if it was blown so ''no'' your motor isnt blown
Old Feb 11, 2004 | 05:45 PM
doublejz's Avatar
Default Re: (USDMDC2)
Most likely your headgasket. Keep an eye on your coolant. See if its blowing outta the reservoir or turning a weird color.
white = coolant
blue = oil
black = running rich as hell
Old Feb 11, 2004 | 08:18 PM
WCI's Avatar
WCI
Default Re: (doublejz)
yea check too see if your coolant looks like this
Old Feb 12, 2004 | 07:17 PM
jdmcivicdx's Avatar
Default Re: (WCI)
well i checked my coolant. looks fine. i pulled my spark plugs and one had some burnt on oil at the tip of it.what does this mean?i tried driving today and i could feel the car not running right. What else can i check before i rip the motor apart?
Old Feb 12, 2004 | 07:37 PM
hondatim's Avatar
Default Re: (jdmcivicdx)
those CEL codes all refer to O2 sensor rich/lean. meaning mixtures are bad due to smoke. With CEL blinking, this is the ECU's way of telling you that you have a catalyst damaging misfire (only reason CEL would blink steadily)
Also, you can have a blown headgasket and not have intemix of oil in coolant or coolant in oil.
have you performed a wet/dry compression test of all cylinders yet?
this would be a good starting point for your diagnosis...
let us know what you find...
Old Feb 12, 2004 | 11:55 PM
bayarea13's Avatar
get a hydrocarbon tester to test youre coolant. if its posative you have a blown head gasket and its time to tear off the head.
Old Feb 13, 2004 | 09:18 AM
jdmcivicdx's Avatar
Default Re: (bayarea13)
thanks for the suggestions. ill go ahead and try them out. ill keep yallposted.
Ozne99
May 27, 2008 08:36 PM
thesoundofturbo
Apr 3, 2008 07:41 AM
damnitamy
Oct 15, 2006 10:20 AM
ReV LiMiT
17
May 26, 2006 08:15 AM
5thgen
Mar 24, 2003 07:15 AM
