my d16y7 motor shakes
Old Oct 9, 2003 | 02:10 PM
ekguy's Avatar
Default motor shakes when i come to a stop
someone plz help me. i have a 98 ek, (d16y7 stock motor) and everytime i come to a stop, my motor starts to shake. any suggestions on how to fix it??? plz help!
Modified by ekguy at 11:29 PM 10/9/2003
Old Oct 9, 2003 | 02:57 PM
turboteg96's Avatar
Default Re: motor shakes when i come to a stop (ekguy)
SO whenever your ideling basically???
Old Oct 9, 2003 | 03:12 PM
ekguy's Avatar
Default Re: motor shakes when i come to a stop (turboteg96)
yeah, basically.. any suggestions on how to fix? never used to shake before
Old Oct 9, 2003 | 03:57 PM
greebler's Avatar
check the rear motor mounts, is it idleing smooth?
Old Oct 9, 2003 | 07:33 PM
haccord2.2's Avatar
Default Re: motor shakes when i come to a stop (greebler)
I had the same problem with my 96 hatch when I first bought it. It has the stock D16Y7 and it idled very rough and would almost die when I would push in the clutch and come to a complete stop at a light. It turned out that before I owned the car the people had the timing belt changed and it was off 1 or 2 teeth on the cam pulley and they had fully retarded the ignition timing to make up for it. So I would check your timing first and see where it is at with a timing gun and then adjust the timing and see if it gets better or worse, then you can come to a conclusion on if it is the timing or not. Well hope this helps, Jordan.
Old Oct 9, 2003 | 09:38 PM
ekguy's Avatar
Default Re: motor shakes when i come to a stop (haccord2.2)
thx a lot jordan, imma check that out...
Old Oct 10, 2003 | 08:24 AM
turboteg96's Avatar
Spray your plug wire's with water and see if the spark is Jumping. Also, any vaccum or exhaust leaks can contribute to a poor idle.
Ian
slow-ef
Mar 26, 2009 10:53 AM
G2_Fella
Nov 8, 2006 10:50 AM
sublimenerd
Sep 8, 2006 09:54 AM
CIVIC96DXcp
Apr 19, 2005 07:47 PM
1987CRXSi
Dec 29, 2004 07:12 AM
