Are my belts too tight? B20b
Old Apr 3, 2018 | 06:42 PM
On1wheel's Avatar
Default Are my belts too tight? B20b
was making a squealing noise and sounds like it's coming from the harmonic balancer. I installed a new one and belts, same sound. Only happens at idle. Pulley looks like its wobbling. Any ideas?
Old Apr 4, 2018 | 05:01 AM
DumpdEJ6's Avatar
I like the tuna here
Default Re: Are my belts too tight? B20b
Is the keyway and key on the crank ok? Fitting tightly?
Old Apr 4, 2018 | 05:46 AM
On1wheel's Avatar
Key felt alright. One thing I want sure about is when both pulleys are on shaft there is play, kind of like teeth are worn out.
Old Apr 4, 2018 | 02:32 PM
holmesnmanny's Avatar
pull the harmonic pulley and inspect it, could be about to come apart
Old Apr 4, 2018 | 05:07 PM
On1wheel's Avatar
Brand new pulley
Old Apr 4, 2018 | 07:21 PM
on any belt, on the longest side of the belt, in the middle of that side, with your thumb and index finger, twist the belt, it should only twist 90 degrees or so, if it twists more than that then it's too loose
you can always spray wd40 or anything really gently onto a belt and if the noise changes you atleast found the circuit with the issue
Old Apr 5, 2018 | 12:06 PM
On1wheel's Avatar
Tried this seems to be a little tight. The old alternator belt had a chunk missing from it, might be alternator pulley? Will test more tomorrow and post it
Last edited by On1wheel; Apr 5, 2018 at 12:07 PM. Reason: Stops making this noise above 3k rpm
Old Apr 5, 2018 | 05:56 PM
take off the belts and turn each pulley with your hand, see if one has roughness, more likely the alt bearing
Old Apr 6, 2018 | 12:03 PM
09chaplak's Avatar
Loves Tossing Salad
Just take the alternator belt off and start the car. No noise, you know it's that.
Old Apr 10, 2018 | 04:52 PM
slowcivic2k's Avatar
The sound the system is making is that of diode overload in the alternator. This sound is common to a lot of alternators with bad diodes or brushes. If you do not have a stethoscope, remove the drive belts one at a time when the sound is being produced. From experience, the two main causes are alternator diode failure, and pulley bearing failure. Each case tends to be unique in some way (something usually contributes to the failure).
Old Apr 27, 2018 | 10:53 AM
On1wheel's Avatar
changed the alternator and sound is gone. Thanks guys
Old Apr 28, 2018 | 01:54 PM
On1wheel's Avatar
https://youtu.be/e78fKgrH62I
Old Dec 28, 2018 | 08:44 AM
On1wheel's Avatar
just update the sound was pcv valve. It would come and go and was very hard to tell where it was coming from. Deleted it with catch can and now sound it gone.
mikey88
Apr 19, 2017 10:57 AM
crxaddikt
12
Sep 22, 2014 01:37 PM
civic=goodgasmileage
Honda Civic (2001 - 2005)
Jun 6, 2010 08:39 PM
dcdcdc
Jan 30, 2008 02:49 PM
GSR_hatch936
Jan 19, 2008 11:43 AM
