Msd Sci and 2 step module?
Is it posibble to hook up the standard Sci with a 2 step module? Most of the Msd ads say to use with the ones with the rev limiter. Any one know? Also does Msd make a pill for 9300 or 9500?
I have the Sci and it doesnt have a 2 step? I basically just need something for a rev limiter for the Sci, any suggestions?
Does you SCI have a place for a revlimiter chip? If so then plug the 2 step module ($56) into and follow directions.
BTW the clutch start switch makes a good ground circuit for setting the lower rpm limit.
If you SCI didn't come with the built in limiter, then your gonna have to do some adding on.
