msd problems..or is this normal
ok when I first installed my msd unit and the blaster coil...the car started up extremly fast...I was like whoa....it doesnt seem to do that anymore and I was wondering if there could be a problem with the unit or the coil? if there was would I have problems even starting the car? how could I check to see if everything is working the way it should
changed the plugs and the car is running a lot better now..the white parts of the plugs look like they are burnt at the bottoms...car even starts better with the new plugs...any ideas why this happened???
mods: msd sci, msd blaster coil, msd cap, msd wires, 2.25 inch cat back exhaust, cai
The times I have glanced at the above mentioned, I never have seen what the voltage is, does anybody know???
OEM kicks out around 40,000 volts...
The times I have talked to peeps about up-grading mine (ignition, etc...) they told me to leave it stock. Unless, I was going to boost a high amount, or go with a high C/R...
[Modified by 88_SC_CRX_Si, 8:09 AM 6/17/2002]
