MSD Ignition Blaster SS install help.
Old Nov 26, 2008 | 03:07 AM
TURKISHFORCE's Avatar
Default MSD Ignition Blaster SS install help.
install for b16a1 vtec ef9 civic
http://img179.imageshack.us/my.php?image=blasterxj5.jpg
Old Nov 28, 2008 | 08:32 AM
hfrex's Avatar
your just trying to install the coil?????
Old Jun 9, 2009 | 11:24 PM
Default Re: MSD Ignition Blaster SS install help.
ok
http://www.msdpower.com/download/82901.pdf
how install from msd blaster to orginal honda cap (wire/cable) there is no 5 input wire plug connection on cap???
http://www.hiperformancewarehouse.co...ducts_id=23902
Old Jun 10, 2009 | 04:45 AM
Utzz's Avatar
MSD Part 8803
I think that's what you're looking for.
Old Jun 11, 2009 | 11:38 PM
tanks...
Old Jun 18, 2009 | 01:44 AM
same install with ???
MSD Blaster 2 coil
http://www.hawkinsspeedshop.com/cate...es/1218203.jpg
Old Jun 18, 2009 | 06:00 AM
Utzz's Avatar
Yep...it's just a coil. Don't use the ballast resistor that is shown in that picture.
Old Jun 18, 2009 | 08:40 AM
and can i use normal Spark Plug Wires from vtec.
and is this the ballast resistor
http://msdignition.carshopinc.com/pr..._id/40350/8214
way not use install like the picture???
edit..
http://www.msdignition.com/forum/sho...llast+resistor
Old Jun 18, 2009 | 09:49 AM
Utzz's Avatar
The ballast resistor is needed for points-style ignitions. We don't have points-style ignition. Why that guy is using the resistor in your picture is beyond me (the coil output wire has me lol'ing).
"and can i use normal Spark Plug Wires from vtec." - I don't understand...nor do I understand why you posted that link to the MSD forums when that post is about the guy using an actual MSD distributor...which you're not, from what I've gathered so far.
Just stick with stock...it works, it's proven, it's reliable...even on 400whp+ turbo'd Civic's.
Old Jun 19, 2009 | 09:39 AM
j
ajajajajajajajajajajajajaaaaaaaaaaaaaaaaahrrhrhrhr hrhhhgg
the never ending story ..
have install the blaster2 with self modification cap.
first run ok but when i drive fast lots off ignition error misfire more then before
maybe try with Ballast Resistor for test..
news news news
now allright all ok , i have rong wire install
thanks................ THE END OF THE STORY
coupe_hybrid
Mar 30, 2005 06:22 PM
CimorelliCRX
Aug 16, 2003 05:34 PM
scrubachu
Sep 26, 2001 02:32 PM
