MSD external ignition module questions
Old Dec 21, 2004 | 08:28 AM
NitrousB.I.G.'s Avatar
Default MSD external ignition module questions
Just wondering if I can use this with a stock distributor. I did another more detailed post but got no replies. Here is the link. https://honda-tech.com/zerothread?id=1090029
Old Dec 22, 2004 | 04:14 AM
civic-4-ges's Avatar
Default Re: MSD external ignition module questions (NitrousB.I.G.)
Yes, you can use one, you just need to run 4 wires total in and out of your distributor.
Bascially you will take the positive and negative wires going to your exisitng coil, and connect them to the MSD box. Then you will take the two MSD coil wires (black and orange i believe), and run them to the stock coil. There is of course a little more to it than that, actual wire colors are on the MSD site
Old Dec 22, 2004 | 04:11 PM
Default Re: MSD external ignition module questions (civic-4-ges)
That sounds like wiring up an MSD ignition box. Ive already got a digital 6. What I am talking about is on the MSD site on the page for their new distributor, there is a note on the bottom of the page that says "Note: External Ignition Module, PN 6305, and Coil,
PN 8235, must be purchased separately (not shown).
". What I am wondering is if the external ignition module PN6305 is an ignitor and can it be used with a stock distributor. I think that my stock ignitor is pooched and would like something that wont fry.
Old Dec 22, 2004 | 06:27 PM
My bad, I guess I interpreted your first post wrong. Sorry!
Old Dec 22, 2004 | 06:42 PM
atcrx's Avatar
I would assume that your digital 6 box will work. It only needs some sort of trigger to make it fire.
Old Dec 22, 2004 | 07:06 PM
Default Re: MSD external ignition module questions (atcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atcrx &raquo;</TD></TR><TR><TD CLASS="quote">It only needs some sort of trigger to make it fire.</TD></TR></TABLE>
Thats what im asking.
redlinez_r_us
May 28, 2010 12:05 PM
boostin b16
Mar 18, 2003 12:32 PM
RAWB
Aug 20, 2002 06:36 PM
