msd 6al2 installation help
Old Apr 22, 2009 | 02:24 PM
B18Cyko5's Avatar
Default msd 6al2 installation help
ok so i bought a msd 6al2 ignition box with blaster ss coil and extreme power cap. i put everything together and when i wired the 2 step activation wire to the clutch switch the car only turns over when i turn the key and push the momentary button. also i'm not getting spark so i bought new ngk's and still nothing i and using the 5 prong relay msd sells. the wire i spliced into from the clutch switch is the blue wire. please help?!
Old Apr 22, 2009 | 03:04 PM
srmofo's Avatar
Default Re: msd 6al2 installation help
Y/m/m ???
Old Apr 22, 2009 | 06:15 PM
B18Cyko5's Avatar
it's a 94 teg with ls/v setup stock b18a1 bottom and stock b16a2 head. obd1. skunk2 intake mani, that's about it. the car has a 94 gsr dash and the wire harnes is from the 99-00 si the car had a b16a2 in it when i bought it, so it's pretty rigged, lol. thanks for the help
Old Apr 24, 2009 | 03:05 PM
fastrxu's Avatar
99-00 si harness? pretty rigged? that's about as rigged as you can get without making your own harness out of wire and wire connectors
it's going to be hard to troubleshoot because of that
B16aCRXSi
Sep 13, 2009 05:36 PM
vtek9
Aug 27, 2007 07:40 PM
vegaskurt
Oct 4, 2005 01:29 PM
fastludeh22
Apr 21, 2003 05:26 PM
