Mounting issues
Old Feb 8, 2014 | 07:38 AM
DeeJHonda95's Avatar
Default Mounting issues
Put my h22 into my eg and the transmission bracket lines up to tranny mount.. The rear mount is also bolted up but then the driver side mount isn't fitting in the bracket correctly... And the belts are rubbing on the frame.. What the hell is going on?
Old Feb 8, 2014 | 08:16 PM
fcm's Avatar
fcm
Old Fart
Default Re: Mounting issues
I assume you mean frame-rail, as it is a unibody, there is no "frame".
Can you post a picture?
I can only assume you have the wrong motor mounts, or you have done something wrong.
So, what motor mounts are you using and where did you get them? 94
Old Feb 12, 2014 | 05:26 PM
It barley rubs.. Maybe a 1/8 inch clearance issue between the belt and frame... My co worker said tho just notch out what I need.. But for now I just took off the power steering and am gonna do a manual conversion on the steering rack itself so I could switch back to power if I chose too
BryanPendleton
Mar 22, 2006 07:57 AM
O16581724 5 2 5
May 30, 2005 10:35 PM
AdamQ3B85
Nov 4, 2003 11:19 AM
Aklude_h22a
Oct 24, 2001 05:58 AM
