Motor Swap into EG hatchback problems...
I just swapped and b20vtec into my 93 CX hatch, I am using a B16A2 head. The promblems consist of this.
No vtec engagement...
(no oil pressure or vtec solenoid filter needs changing?)
I have CEL codes 6 and 21. I checked #6 but it seems to me i need a new ECT sensor and code #21 i will go buy a new filter and changed it out hoping it will fix the problem.
I wired the vtec solenoid to pinout A4 which is a orange/white wire not yellow/green. Then i wired the knock sensor to pinout D3 which is a brown wire, and the vtec oil pressure i wired to pinout D6 which is orange/blue.
Please help thanks much.
Modified by straywalker at 12:30 AM 11/29/2004
(no oil pressure or vtec solenoid filter needs changing?)I have CEL codes 6 and 21. I checked #6 but it seems to me i need a new ECT sensor and code #21 i will go buy a new filter and changed it out hoping it will fix the problem.
