Motor install help
My cousin and I installed a used motor into the accord. The motor cranks but won't turnover. All 4 cylinders all sparks going into it. Sometimes, it would turnover for about 2 seconds then die. Compression numbers:
Cylinder 1: 180
Cylinder 2: 155
Cylinder 3: 160
Cylinder 4: 180
Cylinder 1: 180
Cylinder 2: 155
Cylinder 3: 160
Cylinder 4: 180
Yeah, sorry. That's what I meant. I took off the distrubitor to put on the new motor but never took out the plugs on the cap so they should be in order. There should be fuel. I forgot to hook up the fuel line and when I connected the battery, fuel dripped all over the driveway. Will have to check timing again.
I don't know if this will help, but whenever we do a swap, right before we start, we make sure and prime the fuel system a couple of times to make sure theres plenty of fuel.
Also, check ALL of your grounds. That's usually the won't start culprit.
k2civic
Mar 23, 2004 08:17 PM
