MOROSO Dry Sump Problem
Old Apr 4, 2005 | 11:15 AM
West Werks's Avatar
Default MOROSO Dry Sump Problem
Does anyone have the MOROSO B-Series Dry Sump setup? If so did you have a problem with the htd belt tracking to one side of the pulley? I have damned near tried everything imaginable, i.e. adjustments, tensions, aligments, and the belt wants to track off towards the front of the engine.
Any suggestions, fixes?
Thank you.
Old Apr 4, 2005 | 02:28 PM
civicross's Avatar
Default Re: MOROSO Dry Sump Problem (VenGeanceDrag)
It sounds like the pump itself is tilted to one direction. Did you try a different belt?
Old Apr 4, 2005 | 02:44 PM
West Werks's Avatar
Default Re: MOROSO Dry Sump Problem (civicross)
Thats my next option the thing is everything is brand new, but thats pretty much my last and only option, besides bending the mounting bracket which I am hesitant on doing.
Old Apr 4, 2005 | 02:52 PM
DonF's Avatar
Either the pump has an angle, or one of the pulleys has a taper. I doubt the last one. Shim until correct.
Old Apr 4, 2005 | 02:54 PM
West Werks's Avatar
Default Re: MOROSO Dry Sump Problem (DonF)
I was trying to figure out how to shim it, it only mounts on 2 points (2 of the a/c mounting holes) so I dont think I can shim it correctly.
Old Apr 4, 2005 | 03:12 PM
civicross's Avatar
vltjr
May 5, 2011 08:39 AM
vinuneuro
Oct 26, 2007 05:14 AM
Ian.G
Honda S2000
Feb 5, 2007 10:16 AM
ckur1y
Jan 31, 2006 08:12 PM
Mike banX
May 28, 2004 05:01 AM
