which mod should i do next?
Old Aug 1, 2002 | 02:03 PM
quik2kSi's Avatar
Default which mod should i do next?
i have a 00 Si with AEM CAI, apex n1 exhaust, and jdm 4-1 header with testpipe, and soon to be advancing the timing 2 degrees this weekend but i can't decide what to do next. i don't want anything to drastic like a whole new valvetrain or turbo but maybe like a vtec controller or pulleys and cam gears? what do you guys think? are pulleys worth it? any suggestions on what ot get next? thanks
Old Aug 1, 2002 | 02:29 PM
tmg's Avatar
tmg
Default Re: which mod should i do next? (quik2kSi)
i'd stay away from the pulleys. go for the cam gears, they'll reap good power when tuned and dyno'd. the pulleys take too much out of your electrical system and it's not worth the few horses on your setup. electronics like a vafc won't do you too much either but it's good to have in prep for a increased setup. good luck
Old Aug 1, 2002 | 02:31 PM
sackdz's Avatar
Teken, I hear he's good in the sack
Old Aug 1, 2002 | 11:03 PM
D16Z6racing's Avatar
Default Re: which mod should i do next? (themi6group)
I wasted my $ on AEM pulley kit. My AEM fuel set up helped with gas milage.
Old Aug 2, 2002 | 01:56 AM
.BULLET.'s Avatar
From: kapalua,los angeles,las vegas, HI,CA,NV, United States
get the CTR intake cam...trust me...plus, u'll hear vtec like u've never heard before..its a good cam..its reliable..good luck man
Old Aug 2, 2002 | 08:21 AM
sackdz's Avatar
Default Re: which mod should i do next? (PEN15teamJDM)
Get a Quiafe or factory LSD High Final drive, light flywheel, and clutch while th tranny is down.
Old Aug 2, 2002 | 10:35 AM
Jeff C's Avatar
CTR intake cam
that would be a nice mod
what about nitrous?
Old Aug 2, 2002 | 11:52 AM
Grimm's Avatar
Default Re: which mod should i do next? (Jeff C)
how about just some interior engine work. new rods, pistons, cam shaft, lightened fly wheel, hondadata stage 1?
Old Aug 2, 2002 | 12:06 PM
Spade's Avatar
The easiest and most obvious answer is V-AFC. You can tune more power out of those. Then follow that with Cams and Cam gears. If you don't want to do both at the same time then do the Cam Gears first.
Old Aug 2, 2002 | 12:12 PM
WAFFLES's Avatar
Default Re: which mod should i do next? (sackdz)
bwaaaaaaaaahahahaha! Good One!!!
I say R cams, cam gears and VAFC.
Old Aug 2, 2002 | 12:21 PM
714eg's Avatar
Default Re: which mod should i do next? (WAFFLES)
SupraRXZ
Feb 17, 2006 03:02 PM
hondaswitch2
May 12, 2003 07:07 PM
slowman
Jun 17, 2002 12:25 PM
erikjohn19
Jul 18, 2001 07:02 PM
