mini me dont understand this
So I did a mini me and it started but would die if I didn't stay on tue gas now it doesn't start I have fuel air and no spark I've timed and timed it nothing works this car is prob after prob after prob if I can't fix this im junking this piece of ****
How about this
Its a d15b1 block z6 head pr3 ecu chipped tuned pm6 intake manifold crx si dizzy
I have fuel squirting when I take the fuel rail line off I seem to have no spark but the car turned on earlier
So troubleshoot for no spark.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%2A%2A%2A-basics-no-start-diagnosis-101-%2A%2A%2A-1992733/
or it could be your timing you need an adjustable cam gear and advance it 4.5 degrees for the 'half of tooth off' but if you already did then its your dizzy you need a z6 dizzy
yeah I know I've just been so dam broke lately. I have a vtec converted p06 chipped and tuned and a z6 distributor and z6 injectors and fuel rail
And can't I just cut the injector plugs and distributor plugs and wire the obd1 up directly?
instead of buying conversions harnesses
nahh i mean you could and there is write ups out the but trust me save your time and buy a conversion harness atleast a cheap one from ebay or if you want a good quality one buy the one off ebay from mono tech everything is easy with his harness
I'm just gonna be staying obd0 till I get a swap worth putting cash into thanks for your help guys
menappi
19
Jul 27, 2005 09:57 PM
sodacan33
12
Jun 22, 2004 08:47 PM
USDM 4G VTEC
Jun 25, 2002 01:22 AM
