milky oil
Old Aug 15, 2011 | 09:56 PM
YuJin's Avatar
Default milky oil
So I just finished putting together a b16 and i started leaking oil from my cam seals. As I was replacing them, I noticed that my oil was milky. I drained my oil from the motor, replaced the headgasket, and put coolant in the radiator. put in about 3/4 of the coolant mix and I am noticing that coolant is coming straight out of my oil pan. When I took off the head, coolant passages in the block were still holding coolant. What could my problem be?
Thanks
Old Aug 16, 2011 | 01:19 AM
mouab18c1's Avatar
Default Re: milky oil
So you're saying as you are pouring coolant into your radiator, the coolant is coming through you oil pan drain bolt?
Old Sep 5, 2011 | 09:12 PM
YuJin's Avatar
yes, coolant goes into the radiator, comes out of the oil pan drain plug.
Old Sep 5, 2011 | 09:18 PM
famous323's Avatar
head gasket!!!!
Old Sep 6, 2011 | 02:47 PM
dc4teg's Avatar
Originally Posted by famous323
head gasket!!!!
Not to sound like a dick but I have seen it. Could you have put it on upside down or backwards? My buddy did it. Or there is a crack somewhere...
Old Sep 6, 2011 | 03:04 PM
YuJin's Avatar
I mean, when I put the head gasket on, the up is facing.... the head. The head was a lsvtec head if that makes any difference? I was told it could've been from dowel pins also?
Old Sep 6, 2011 | 03:14 PM
YuJin's Avatar
and also, the coolant passages in the block are holding the coolant fine.
Old Sep 8, 2011 | 04:14 AM
dantamparacer's Avatar
would you happen to be running a oil cooler like the factory one on a b18c1? It has been a long time since i have looked at a B16 and cant remember if they run it or not. It looks like a spacer infront of the oil filter, with 2 hoses coming from it
Old Oct 12, 2011 | 06:47 PM
YuJin's Avatar
no oil cooler. coolant fills in the block
I think as soon as the coolant fills past the block into the head it leaks out the oil pan as fast as I pour into the radiator.
Old Oct 13, 2011 | 01:03 PM
mouab18c1's Avatar
GSR's do not come with oil coolers from the factory.
Old Oct 13, 2011 | 04:40 PM
rdssk8rcs1's Avatar
I have seen people hook yp the coolant lines coming off the coolant pipe in the back of teh motor incorrectly. Runnin them from the coolant pipe into the manifold instead of to the IAC valve.
Just a thought
Old Oct 14, 2011 | 05:10 AM
eldermichael's Avatar
Just a thought
This or your block is facked.
Old Oct 18, 2011 | 01:33 PM
207hondaguy's Avatar
its either a good-sized crack or a coolant hose routed improperly. even if it were a bad HG or uneven mating surfaces the fluid would not poor out THAT fast
Old Oct 18, 2011 | 07:06 PM
ken9's Avatar
That hella scary.. Was that rebuild engine or used one?
Old Oct 25, 2011 | 04:18 PM
10psiLsEf2's Avatar
cracked block somewere!
Old Oct 30, 2011 | 02:21 PM
driftn_silvia's Avatar
definitely sounds like a cracked block.
96accordsir
Aug 1, 2011 04:27 PM
cristegra09
May 14, 2009 11:45 AM
orange94teg
Apr 5, 2008 07:43 PM
92jdmhatch
10
Dec 28, 2004 07:53 PM
Halo
Aug 12, 2002 06:27 PM
