Manual steering rack swap
I have a 93 civic dx 4 door and i want to put a Manual steering rack from a hach or coupe. I think all 4 doors come with power steering, has eny one done that swap? Is it bolt on or are the mounting points not the same?
I beleive that unless the car is being raced on a track ratio is a bunch of BS. I would rather have a maual rack than a looped power rack anyday.
only bad thing if you do go to a manual rack you need the bracket that holds the manaul rack on the right side being that a manul rack is thinner than a power rack.
what would you like me to explain? obviously you have driven with slicks, you know its not an easy task. When going around the pits or even getting off the line isnt fun with slicks I would take that over then giving a slight budge at over 100 mph and losing control just because I wanted to feel comfortable with the power rack.
What I did to mount my manual rack was I got the ES bushing for the power rack and doubled up the bushings(using the original and the ES bushing) till I found the correct bracket.
aasarsak
21
Jun 9, 2014 10:02 PM
all_up_in_uranus
Nov 6, 2009 04:42 PM
