making own catback
Old Dec 28, 2003 | 09:23 PM
bseriesboosted's Avatar
Default making own catback
My friend and I are thinking of making our own catback exhaust system for his nissan 200sx. The idea is to get piping from autozone and weld them together to make a custom and cheap catback...
is this a good idea or should he just get a aftermarket system?
Old Dec 29, 2003 | 03:48 AM
fast-rex's Avatar
Default Re: making own catback (bseriesboosted)
what are you planing to spend ?
Old Dec 29, 2003 | 07:27 AM
Default Re: making own catback (fast-rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast-rex &raquo;</TD></TR><TR><TD CLASS="quote">what are you planing to spend ?</TD></TR></TABLE>
on the custom job we are thinking of doing ourselves we are looking at around 55 bux plus he allready has a muflfer
Old Dec 29, 2003 | 08:17 AM
anyone
Old Dec 29, 2003 | 09:32 AM
falcongsr's Avatar
What is this crap?
do you have a mig welder? do you have welding experience?
if you know what you're doing then you don't need us to tell you do go ahead and do it. DO IT!
Old Dec 29, 2003 | 09:51 AM
Daemione's Avatar
Default Re: making own catback (falconGSR)
Make sure to get some kind of resonator or it will sound poopy . . . .
Also check out jegs for pretty inexpensive piping & mandrel bends. They also sell bends with swaged ends so you theoretically wouldn't even need to weld . . . just slip fit things together & use some good pipe clamps.
Old Dec 29, 2003 | 10:07 AM
Default Re: making own catback (Daemione)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daemione &raquo;</TD></TR><TR><TD CLASS="quote">Make sure to get some kind of resonator or it will sound poopy . . . .
Also check out jegs for pretty inexpensive piping & mandrel bends. They also sell bends with swaged ends so you theoretically wouldn't even need to weld . . . just slip fit things together & use some good pipe clamps.</TD></TR></TABLE>
I have some welding experince and yes i have a mig welder so im thinking we can pull it off my question is what would there be a huge difference between crush and mandrel bends..
the pipes we are looking at have the ends like your talking about we were just going to fit them together and the weld all the way around to make sure we have no leaks. As far as the bends go i think there's only going to be like 2 90 degree bends that we can probably make two 45's and just use the crush bent on those to save time and money.
Old Dec 29, 2003 | 10:09 AM
and can you just pic a resonator up at a local exhaust shop if so what is the going price for one cuz we are trying to keep this project below like 75 bux
Old Dec 29, 2003 | 10:26 AM
Team 4's Avatar
Get the mandrel bends, as the crushed bends reduce the i/d too much.
Old Dec 29, 2003 | 12:46 PM
Default Re: making own catback (REVHARD_EF)
what about the resonator how much do those run$$$$
Old Dec 29, 2003 | 12:51 PM
Daemione's Avatar
If you're hard-set on staying below $75, I doubt you're gonna fit mandrel bends & a resonator in . . . And frankly, it's not going to sound good or perform well.
Personally, I think spending the $75 on a high quality Magnaflow resonator is an EXTREMELY worthwhile investment.
For my (theoretical) custom exhaust, I was figuring spending about $200 (sans labor) . . . . that's w/ all aluminized piping & magnaflow components. Plus another $100 for a resonated Carsound cat & $50 for an extra moroso spiralflow resonator (if needed).
Old Dec 29, 2003 | 12:56 PM
I'll talk to nathan and see if the budget will allow for some mandrel bends and a high flow cat and resonator but I'm pretty sure if its much over 100 bux he will just buy a aftermarket catback
Old Dec 29, 2003 | 02:34 PM
onePOINTsix's Avatar
i payed around $75 for mine including a flowmaster (no resonaters needed) and got my mandrel bends from http://www.summitracing.com
Old Dec 29, 2003 | 08:58 PM
CleenSi
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daemione &raquo;</TD></TR><TR><TD CLASS="quote"> <U>Make sure to get some kind of resonator or it will sound poopy . . . .
</U> Also check out jegs for pretty inexpensive piping & mandrel bends. They also sell bends with swaged ends so you theoretically wouldn't even need to weld . . . just slip fit things together & use some good pipe clamps.</TD></TR></TABLE>
Old Dec 31, 2003 | 08:37 AM
Default Re: making own catback (CleenSi)
well the update is we went searching for piping last night and put it all together in the store to see what we were working with and we have decided to do it all custom and run new hangers and all it will now only have 2 45's instead of 3 90's and 2 45's so we are taking 3 bends out and running under the solid rear axle
oh yea this is just to keep us busy until he orders an after market system
Old Jan 3, 2004 | 04:25 PM
SyDuck's Avatar
i dont think the piping from autozone are mandrel bent.. the one in my area only has the wackazz bent pipes mandrel bent is good
HCJDM1
13
Jan 28, 2007 03:33 PM
loner714
Jan 6, 2007 08:20 AM
d357r0y
Sep 20, 2006 05:03 AM
604Squad
Nov 15, 2005 01:00 PM
GOLDBERG
13
Jan 7, 2004 02:38 PM
