Lsvtec conversion questions?
Old Apr 9, 2004 | 07:58 AM
B18BEGG's Avatar
Default Lsvtec conversion questions?
I'm new into the import scene. I did my search but still alittle confuse?
As of right now I have a 1993 civic egg with B18b ls motor. And I just bought a 1999 GSR vtec cylinder head and wanted to convert it to lsvtec. My first question is could i still use my DC sport 4-1 LS header or would i have to buy a new one? Second, could i still use my AEM Ls cam gears or would it not work with my GSR head? Are the cam gears different?
Last question is that my GSR cylinder head need a distributor, i think its OBD 2 but i was thinking of keepin it obd1. Could a 94-95 GSR OBD 1 distributor work on my 99 GSR head?
Pretty much i dont know much about cars or engine parts so any info or help would be greatly appreciate.
Old Apr 9, 2004 | 07:19 PM
B18BEGG's Avatar
Default Re: Lsvtec conversion questions? (B18BEGG)
no reply ... dang...
Old Apr 10, 2004 | 01:11 AM
soulstream's Avatar
you can use the same LS header, same AEM LS cam gears, and you can use an obd-1 gsr distributor, all with no problem.
Old Apr 10, 2004 | 02:25 AM
SprayinCX's Avatar
Default Re: (soulstream)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soulstream &raquo;</TD></TR><TR><TD CLASS="quote">you can use the same LS header, same AEM LS cam gears, and you can use an obd-1 gsr distributor, all with no problem.</TD></TR></TABLE>
well he summed it up pretty good.
but you will also have to do something about those dowel pin holes or the dowel pins themselves.
Old Apr 10, 2004 | 06:20 AM
Sliced Beard's Avatar
Default Re: (SprayinCX)
for dowel pins you can get the eagle dowel pins so you dont have to pay a machine shop to drill the holes out.
Old Apr 10, 2004 | 12:02 PM
SprayinCX's Avatar
Default Re: (dirtyd463)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtyd463 &raquo;</TD></TR><TR><TD CLASS="quote">for dowel pins you can get the eagle dowel pins so you don't have to pay a machine shop to drill the holes out.</TD></TR></TABLE>
but what head gasket would you use?
i know the golden eagle dowel pin you have to you their head gasket with them. because a oe ls gasket, the holes are to small for the pins to go through.(i speak from experience)
Old Apr 10, 2004 | 08:25 PM
B18BEGG's Avatar
Thanks alot for replying back guys. I appreicate.
Now I know I could pretty much get my project going. ANd yes I'm planning to get the Golden Eagle Lsvtec Kit. Again thanks .
meric0786
Sep 26, 2005 04:43 PM
ITR1071
Dec 25, 2002 03:54 PM
civura R
Oct 4, 2002 02:58 PM
