Lsv smokes at high rpm help
Hey what's up my lsv turbo smokes at high rpm it's blueish gray smoke at like 6k rpm. I did a compression test while the car was cold the numbers where 180 acrros the board. Hat could be the issue is it rings or valve guide seals?
if it also smokes from a cold start like first start of the day a little bit its the valve seals
smoke at high rpm and cold start are usually the valve seals
FeRReTTi
May 3, 2017 05:54 PM
