LSD Dx tranny ?
hey i recently found a LSD ZC tranny .. but the only thing is that ima running turbo. so i would like to use the DX tranny for longer gear ratios.. i was wondering if it was possble totake the DX gears and put it in to the Zc tranny ?
i think i have an idea.. probably just swap the main shaft gears over from dx to the zc tranny ?
can someone answer some of my questions thanks!!
well im not certain, but an educated guess would say you could, they're both d series in specifications, but for some reason i think it'd be easier to toss the dx gears into the zc. But this is just an educated guess. Im sure some others know for sure and in that case they'll help you out i hope or you could just try it out...If worse comes to worse you can just swap gears and keep everything else in there.
thanks for the reply
ya for sure i would want to use the ZC tranny with dx gearing coz Zc has equal length shafts
dang i wanted to know how hard it would be and if there is any documents on how it would be done ..
