Ls vtec swap with ac in eg
Old Nov 14, 2016 | 04:04 PM
Shay Cothran's Avatar
Default Ls vtec swap with ac in eg
I'm swapping my ls vtec into a 93 eg coupe and have all ac components from my 96 integra. I am trying to find out the cheapest way to have ac in the eg. Everywhere I've read suggest to use d series compressor with crv mount and use everything else from the eg. I don't have any ac components for the eg. I'd much rather use the integra ac system considering I already own it. Is there any way I can use the integra ac system on the eg? Otherwise I'd have to buy all the ac components for the eg and have to have a r12 system or convert to r134a.
Old Nov 15, 2016 | 11:08 AM
fcm's Avatar
fcm
Old Fart
Default Re: Ls vtec swap with ac in eg
The only issue you would have is mounting the full size Integra condenser into the Civic, you will most likely have to make some custom brackets to hold it properly in front of the rad, and if you trigger the condenser fan at the same time compressor comes on you should be good to go.
The other issue may be the A/C unit, [evaporator housing] I am not sure they are exactly the same, you will have to see if your Integra one fits into the Civic, if not a trip to the bone yard, [PicknPull] to get a Civic one is in order, the evaporator itself should fit into a Civic unit without any mods. 94
Shay Cothran
Nov 14, 2016 07:40 PM
tallguy21
Mar 8, 2012 02:02 PM
tico
Aug 30, 2011 06:43 PM
lonnieboost
May 2, 2004 05:11 PM
