LS/VTEC PROBLEMS(WONT START)
I RECENTLY PUT A STOCK GSR HEAD ON A LS BLOCK WITH GSR PUMPS AND GOLDEN EAGLE KIT. I HAVE THE TIMING AT TDC AND THE IGN WORKS (IM GETTING SPARK) .ITS DEF. GETTING FUEL AND HAD PLENTY OF AIR. ANYONE WANT TO TAKE A TRY.THING JUST WONT START.
hey by the way I had the same problem the other day...here's the problem..the car rotates but will not fire.. first of all find out what type of cams your using. Get the spec for the cams. because there's no pressure in the chamber to fire up you car. If you have gsr cams. use the spec for the gsr cams..if you use b16 get the spec of that..try that and you car should work
Tong.Y
Apr 8, 2010 04:59 PM
99EletronblueSI
Nov 1, 2004 01:01 PM
