ls/vtec problems
Old Jul 17, 2004 | 02:42 PM
Mike banX's Avatar
Default ls/vtec problems
this is my motor
It has a 1998 Type-R Cylinder Head, The bottom end consists of a 1996 LS Block with spoon sports pistons and brand new bearings. It has a STR Competition Fuel Rail with a paxton fuel pressure regulator., Skunk 2 Cam gears, DC Sports 4-2-1 Header to a full Apexi N1 exhaust. The suspension consists of Tokico non adjustable shocks and Neuspeed Race Springs. The transmission is a JDM b16a and has a Spoon Sports Flywheel
ok and this is what happened from the start...
i was driving one day and i stopped and i noticed i was leaking antifreeze, i drove the car home and it was above half on the temp meter, after that i let the car sit for about 1 week and i fixed the leak then i started the car and it was runnin like it was misfiring so i replaced the spark plugs and it ran normal, but after all that i noticed that my car was running lean, it used to run rich and when i got on it it would go to stoich, now when i drive it sits at stoich and when i get on it it goes to lean and it doesnt go back to stoich after i go into vtec a few times it will stay lean.the car feels like it lost power since i let it sit and had to replace the plugs
i tried changing my fuel filter and i switched out my injectors with another set of b16 injectors and it still was running the same.
and also i dont have a check engine light so i have no clue what the prob is, does anyone have any idea??????????????????????????
Old Jul 17, 2004 | 05:53 PM
kwil6666's Avatar
Default Re: ls/vtec problems (Mike banX)
did you make sure you new plugs are gapped right ?
keith
Old Jul 17, 2004 | 06:30 PM
Mike banX's Avatar
Default Re: ls/vtec problems (kwil6666)
they was a gap when i got them, and would that have anything to do with my <A TITLE="Click for more information about car" STYLE="text-decoration: none; border-bottom: medium solid green;" HREF="http://search.targetwords.com/u.search?x=5977|1||||cars|AA1VDw">car</A> to be runig lean??? i didnt think that was relative to fuel flow,
but i dont know much help me out guys
Old Jul 18, 2004 | 09:28 AM
Mike banX's Avatar
Old Jul 18, 2004 | 04:14 PM
Mike banX's Avatar
Mjm2392
Oct 31, 2013 02:44 AM
DShowers
Mar 21, 2006 05:31 AM
12secondclub
Aug 26, 2004 11:04 AM
CivicForSale
Apr 11, 2004 06:50 PM
ls_vtec_b18a1
Oct 30, 2002 08:53 PM
