ls/vtec leaks need help!!!!!!!!!!!!!
Old Mar 29, 2003 | 09:58 PM
jdm_integ's Avatar
Default ls/vtec leaks need help!!!!!!!!!!!!!
im havin a problem with my head leaking. it seems to be coming from where i put the plug into the head. i did everything the right way....is there anyone else that has had this problem???? or is the a special way of putting the plug in (i.e. with teflon tape or jb weld or whatever.)
Thanks
Old Mar 29, 2003 | 10:01 PM
MikeMAN's Avatar
Default Re: ls/vtec leaks need help!!!!!!!!!!!!! (jdm_integ)
you should ALWAYS use teflon paste or tape
mike
Old Mar 29, 2003 | 10:15 PM
jdm_integ's Avatar
Default Re: ls/vtec leaks need help!!!!!!!!!!!!! (MikeMAN)
I called up a couple of places to see how they did theirs and this is what they told me : (1) Inlinefour told me to just tap it and screw the plug in, they said they do many this way and they have no problems....hhmmmmm...makes me wonder. (2) I also called Autolink Motorworks and spoke to Kitty (who seems to know her stuff about swaps and **** like that) told me the same thing.....just to tap it and screw the plug in.....hhhmmmmm....and no problems.
Old Mar 29, 2003 | 11:10 PM
MikeMAN's Avatar
im sure it would be fine that way, but whats 89 cents in teflon tape for your extra piece of mind?
mike
Old Mar 30, 2003 | 05:13 AM
jdmcx's Avatar
mike
here here i agree 101%
Old Mar 30, 2003 | 06:29 PM
drumking15's Avatar
Are you sure its coming from you oil passage plug and not you cam seal or vtec seal? Mine came from that area and i though it was the plug but it was my cam seal dripping down...check it out
delsolpetty
Oct 21, 2014 10:06 AM
gutted-dx
Nov 8, 2009 08:31 AM
EG hunter
Apr 6, 2007 11:02 PM
pK1spooled
Feb 13, 2005 04:23 AM
