ls/vtec boosted piston quest.
Old Dec 4, 2007 | 05:48 PM
watanabefan's Avatar
Default ls/vtec boosted piston quest.
im ls/vtec right now and i am going to boost, but i want to upgrade my pistons, is it a bad idea to run usdm itr pistons with about 7lbs. of boost. im going to arp the rods etc. please help...ive heard you can do it but will it be reliable.
Old Dec 6, 2007 | 02:23 PM
integrag's Avatar
yes ive seen 12 lbs constant with no problem
integrag's Avatar
Default Re: (integrag)
and you should have arp rob bolts now
Old Dec 6, 2007 | 03:59 PM
mmuller's Avatar
Mad Scientist
well are you trying to run 7 pounds on a t3 or 7 pounds on a gt45r? not the same thing
but anyways power wise i would say mid 200 is safe
Old Dec 7, 2007 | 12:09 AM
Default Re: ls/vtec boosted piston quest. (watanabefan)
i was planning on using it on do about 7lbs. on a t3 nothing to crazy, yeah i should of done the rod bolts just money was tight my car had just got stolen you no how it is lol.....but as soon as i do the pistons im going to have the rod bolts put on. if i use the itr pistons is it recommended on changing rods or are the b18 rods okay....
Old Dec 8, 2007 | 05:11 PM
integrag's Avatar
if you are going to use b series rods use the ls ones but its better to go forged internals....both will be ok if you use a t3
Old Dec 9, 2007 | 12:00 AM
tight...sounds good, i get school money soon from fed ex so im going to hook my car up with some good stuff.... thanks for your help.....
Old Dec 9, 2007 | 06:14 AM
maxpsi's Avatar
Default Re: (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">well are you trying to run 7 pounds on a t3 or 7 pounds on a gt45r? not the same thing
but anyways power wise i would say mid 200 is safe</TD></TR></TABLE>
Agreed. Just be conservative on your timing so you don't crack those honda "glass" ringlands.
unusual71
14
Feb 6, 2014 10:22 PM
lsv_dc2
Jun 24, 2011 06:41 PM
LS-turboner
Jan 8, 2010 04:25 PM
petergriffen
Feb 7, 2006 05:40 PM
Phatch99
Apr 10, 2005 03:28 PM
