LS/V-Tec Question.
Old May 25, 2003 | 07:34 PM
Blitzed's Avatar
Default LS/V-Tec Question.
Ok here it is I am helping a clubbie do a swap into a 1990 rex. We are using the 1991 LS B18A1 block, 1994 GSR head, and the tranny from the LS. My question is do we use the air sensor on the top of the GSR throttle body? The info we keep getting from swap shops is there is no sensor there! In fact there is.
Any help is better then no help.
Old May 25, 2003 | 07:37 PM
.RJ's Avatar
.RJ
Default Re: LS/V-Tec Question. (Blitzed)
I wuold use whichever applies to the ECU you are using (sensor/no sensor)
Old May 25, 2003 | 07:38 PM
poison's Avatar
Which air sensor? MAP? IACV? You said "on top of the gsr throttle body" So I am assuming MAP.
MAP sensors are universal. You may use the LS or the GSR, whichever will work.
That's of course if that is what you are referring to.
motrayEG6
Oct 21, 2011 02:00 PM
phyzJunkieCivic
Oct 3, 2006 08:26 PM
AnthraxVX
Mar 23, 2006 10:29 PM
j-robsDA
May 31, 2005 06:48 AM
SiR HatchAlot
Jan 18, 2004 05:39 PM
