Ls swap Help!!!
Old Jan 10, 2006 | 08:13 PM
4drLsvetc's Avatar
Default Ls swap Help!!!
I am doing a Ls swap into a ex civic. Everything is complete except the distributor, it fits in but the bolts dont align correctly to hold it in. The motor came from a 1991 Teg (OBD 0) and the civic is (OBD 1). I did everything so all the sensor will fit and match the OBD 1 specs. I dont know what type of distributor i need. HELP!!!!!
Old Jan 10, 2006 | 09:09 PM
blackeg's Avatar
Default Re: Ls swap Help!!! (4drLsvetc)
to make it easiest, obd1 distributor, ecu and intake manifold. it should be just about a straight plug and play that way.
Old Jan 10, 2006 | 10:02 PM
freakasis's Avatar
Default Re: Ls swap Help!!! (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">to make it easiest, obd1 distributor, ecu and intake manifold. it should be just about a straight plug and play that way.</TD></TR></TABLE>
by the way he means to get all of those from an ls teg.
kcvi3tstyl3
Apr 6, 2009 08:32 PM
rice is nice
Mar 23, 2008 06:24 PM
Slowass2dr
Jun 22, 2006 09:27 AM
1EK1EG
Nov 19, 2002 12:41 PM
