ls swap does nothing under full throttle
Old Jan 12, 2014 | 08:49 AM
Ej1 DGH's Avatar
Default ls swap does nothing under full throttle
i couldn't get the video to upload so im posting this link to it.
http://www.facebook.com/photo.php?v=...35958253339476
Old Jan 12, 2014 | 08:54 AM
turbonetics3597's Avatar
Default Re: ls swap does nothing under full throttle
whats the check engine light on for what was swapped into it what ecu are u runnin
Old Jan 12, 2014 | 09:33 AM
Ej1 DGH's Avatar
i put an ecu out of a 94 ls in it. its throwing codes 1 and 54
Old Jan 12, 2014 | 09:49 AM
code 1 oxygen content bad primary most likely , code 54 ckf sensor crank fluxuation position i would check the timing. its deffinately in limp mode. so this is just after motor swap? didnt happen while driving.
Old Jan 12, 2014 | 09:50 AM
or if you have your old distributor swap that on there that should clear the problem if its the sensor
Old Jan 12, 2014 | 09:51 AM
what happend to the old motor? if it blew up and coolant got in the exhaust that will kill the o2 sensor
Old Jan 12, 2014 | 01:14 PM
HondaPartsHero's Avatar
Technical Hero
Code 54 doesn't exist on OBD1. Recheck the codes and post a video. Also list your year make and model.
Car Tweaker
Apr 5, 2009 01:13 PM
EGk3nrock
Apr 27, 2007 06:59 AM
xvracing
11
Oct 27, 2003 05:21 AM
blufke
Aug 15, 2002 10:15 AM
Nos4R2
Feb 18, 2002 03:48 PM
