Ls overheating and heat goes away
Old Feb 11, 2010 | 10:26 AM
chrisff521's Avatar
Default Ls overheating and heat goes away
What does it mean when my Thermostat goes almost to the H to overheating while driving normal and even sometimes when the temp. is normal, the heat starts to get cold. What is going on?
Old Feb 11, 2010 | 01:33 PM
delsolproblems's Avatar
Default Re: Ls overheating and heat goes away
It means that for some reason hot coolant is not circulating properly through your cooling system. Air in the system can cause this and so can a bad water pump. Do not drive the car like this, you could blow a head gasket. There are many tests you should perform. Start by checking your coolant levels and then see if the pump is moving any liquid at all. You can check the system pressure as well. Post any new info you find.
NEVER drive a vehicle if the heater doesn't work after the car warms up, at least until you confirm that the coolant system is OK.
Old Feb 11, 2010 | 03:57 PM
chrisff521's Avatar
How do I check if the pump if the pump is working??
Old Feb 11, 2010 | 04:56 PM
HondaPartsHero's Avatar
Technical Hero
check your coolant level
Old Feb 11, 2010 | 05:02 PM
The upper radiator hose should be hot and the lower one should not be. Just to see if it's working you can loosen a radiator hose and a little water should squirt out. Post if the reservoir is empty or the coolant level is low.
Old Feb 11, 2010 | 05:08 PM
FIST321's Avatar
x2
Old Feb 11, 2010 | 05:10 PM
Originally Posted by FIST321
x2
you're actually x3
Old Feb 11, 2010 | 05:16 PM
jdm inc's Avatar
check you coolant and bleed the air out of it!
Old Feb 11, 2010 | 06:15 PM
chrisff521's Avatar
ok tomorrow ill check the coolant level. Theres none in the coolant resoirvoir but ill add some tomorrow. And how do I bleed it?
Old Feb 11, 2010 | 06:21 PM
jdm inc's Avatar
it should be on the top hose.
Old Feb 11, 2010 | 07:48 PM
The bleeder valve is often on the thermostat housing but it varies from motor to motor. I'm sure you can find many how-to guides for cooling system servicing if you do a search via here or Google and they'll explain flushing, filling and bleeding. What's much more important is the fact that your reservoir is empty and you need to find out how you lost the coolant. Bleeding it is pointless if air will just get back in again. When was the last time you checked the reservoir's coolant level? Try to locate where the fluid is escaping.
Old Feb 12, 2010 | 01:27 PM
chrisff521's Avatar
Where exactly is the bleeder on a 94 integra ls? And what does it look like?
Old Feb 12, 2010 | 02:08 PM
It looks just like the brake bleeder valves. If you run a Google image search for Honda Bleeder Valve, pics of them will come up. On a B18B, it's a (10mm?) brass nipple where the upper radiator hose connects to the motor, just above the tranny barcode sticker. It faces the radiator so it's right on the front.
Old Mar 9, 2010 | 12:05 AM
PapaSmurf24's Avatar
TRIAL USER
yea i wouldnt drive at all like that, my homie blew his gasket with same problem as you.
Old Mar 9, 2010 | 07:36 AM
chrisff521's Avatar
it just needs coolant. I filled it all the way up to the top. It needed like half a gallon.! But it runs good now.
Old Mar 9, 2010 | 08:00 AM
Technical Hero
Yoo've got a leak somewhere. Have it pressure tested and repair before the leak gets worse. Worse case you're burning it but I'd check for leaks first.
Old Mar 9, 2010 | 10:03 AM
chrisff521's Avatar
Its not leaking, my problem was the coolant level being too low and I filled it to the top and its all good and stable now.
Joshable14
Jul 20, 2015 10:10 AM
acuralovar
Feb 14, 2010 12:11 AM
turbohb21
Aug 7, 2007 08:43 PM
Nameless Warrior
10
Dec 16, 2006 07:27 AM
ThaSpitefulWun
Apr 5, 2004 09:17 AM
