LS Integra Engine Upgrades.....
I'm about to purchase an Integra LS and I have an extra $800 -$1000 that I'd like to spend on engine internals. I'd like my car to be all-motor, so where do you suggest that I start??
yeah start with a Comptech Icebox, then get a nice 4-1 header with 2.5" collector (you'll lose toeque under stock engine with this though), then get a good exhaust (Apexi N1 maybe?) and get a good high-flow Cat.
Then get the TypeR pistons and good cams like Crower 404's along with S-AFC and mad tuning
800-1000 will get you the crower 404's with the valve springs and retainers
I H E will end up around 1000 and if u can drive u might get a 15.5-6, so save for turbo or get the IHE and eventually save for cams and stuff but remember the H E will be changed wiht the turbo
If you are serious about making power save up for a turbo kit. If you get your basic intake, exhaust, header setup your motor is just breathing better and you'll think you gain power, but when you boost you will definitely feel a power gain. If you boost on stock internals you want to keep your boost level low, then build you block later on when you save up.
