ls crx has fuel no spark and no code help
Old Sep 17, 2010 | 09:40 AM
rel's Avatar
rel
Icon2 ls crx has fuel no spark and no code help
ok got a ls crx did the swap on a bad dash harness started and cut off on its own, replaced dash harness, new distributor and have two tested ecus and they both are doing the same thing injectors firing but no spark and everything is new need help bad ive checked grounds to the ecu,and all new fuses and also have a ground kit installed help
spec:
91 crx dx
b18a1 on a odb0 setup
the ecus are pr4 and pg7
stock injectors, ecu, and motor with crower 402
Old Sep 17, 2010 | 06:00 PM
rel's Avatar
rel
Default Re: ls crx has fuel no spark and no code help
i dont feel so bad now no one nows y its doing it
Old Sep 17, 2010 | 07:10 PM
delsolproblems's Avatar
Were any fuses, fuseable links or relays blown after the car cut off?
Old Sep 17, 2010 | 07:28 PM
rel's Avatar
rel
the only thing the same when i put in the new dash harness is the engine harness and i dont think there are any fuseable link
hondABcrx_
Jan 28, 2015 06:14 AM
JRZ88DX
Oct 31, 2013 12:10 PM
honda_crxzc
Jan 16, 2011 08:51 PM
GSR-TRBO-DA
Aug 21, 2009 09:43 PM
b16_ef
Mid-Atlantic (Sales)
Aug 21, 2006 06:59 PM
