LS 5th gear swap
Ok i have a jdm b16 hydraulic transmission. I dont know the actual code of the transmission but that is what i am told. I am going to be putting in the LS 5th gear and i want to make sure of a few things so i dont order the wrong parts.
Here are the part numbers i am ordering:
23626-P21-335 SLEEVE SET, SYNCHRONIZER (5-R)
23461-P80-000 GEAR, COUNTERSHAFT FIFTH
91003-P21-003 BEARING, BALL (25X52X14/15)
23581-P80-000 GEAR, MAINSHAFT FIFTH
I looked up all the parts from a 95 ls in the catalog i am 99.9% sure i have chosen the correct gears but the other pieces i am replacing i am not sure are the same.
so i am asking if the b16 5/R syncro set is the same as the LS and if the countershaft ball bearing(the one at the end) is the same
Did you read through this?
https://honda-tech.com/zerothread?id=555929
23461p80000, 23626p21335, 5th, gear, honda, hondatech, list, ls, parts, setsynchronizer, sleeve, swap, usa
